UnknownUser1
Android Expert
Yes it automaticaly backed up but im not sure how to reinstate it but if i do then the sticky toggles will come back and thats caused a few issues for me cuz i use them a lot
Caution must be used when manipulating this file since it's a critical system file. You can find it in the /system folder. When I had to change the file I just made a copy and renamed it build.prop.original and then I pasted the new build.prop file into the /system folder then restarted. If I needed to, I could easily revert to the original file by following a similar procedure as outlined above. Again, this is a system file so care should be taken.Yes it automaticaly backed up but im not sure how to reinstate it but if i do then the sticky toggles will come back and thats caused a few issues for me cuz i use them a lot
I remember seeing a lot of conversation about sticky toggles but I'm not sure exactly to what you are referring. Is it something you can easily explain to me again? Thanks.
I don't care which player as long as it has the lyrics displayed like the one that's in the rom now. I really appreciate your willingness to try to give us what we want. It say's a lot about the kind of person you are. Thanks.Okay the new music player has lyrics also but for those who want the connected music player i will give it to you
I understand about the changes apollo made. What I don't understand is what you mean by 'sticky toggles'. I'd like to see if I can reproduce your issue on my phone so I can try to help solve the problem. I know you've already addressed your sticky toggle issue in this thread but I couldn't get a clear picture of what the problem is. That's why I'm asking again. Thanks for helping me understand.In the build.prop theres ad ons at the bottom that are from apallo and its hard to miss. If your toggles stick like mine did you just delete the ad ons idk which specificaly im not dev so i was instructed to delete all and they all work fine now but like i said i have no actual idea if thats what interfeers with my mms
Is it the same thing that was happening in Warp Cream Sandwich?Its when you try to turn wifi 3g unknown sources and they don't stick you back out and it acts like you never pressed it the only way to get it to stick is by rebooting
Sounds like a personal problem![]()
Definitely but on the bright side it's not a ROM issue my man!
How do I know if it's 1G? I haven't had issues that I can detect.Is anyone having 3G issues? Really bad connection slow downloads 1X a lot? Or is it just me
I've always had much better luck if I flash a stock rom before flashing a custom one. Thanks to apollo, I get the images from here: http://androidforums.com/warp-all-things-root/569179-stock-b08c-b08-flashable-roms.htmlSoo I tried your rom today just to check it out cuz I'm a die hard shinjitsu user. But i must say I was impressed. I liked the apps and music related stuff already in it, I also liked the player. I had one issue I couldn't seem to solve. After about 5 reboots or about 2 hrs it would start rebooting by itself over and over like a boot loop. I did multiple data resets, I cleared both caches and fixed permissions. I even reflashed a couple times. Only thing I could think of is I was restoring apps that were backed up using shins rom. But like I said it was definitely a smooth, beautiful rom. I preferred holo launcher though. :thumbup:![]()
Thanks, I guess I never go down to 1G since I've never seen the icon. I'm lucky in my area.By the signal bar it will say 1x or 3g depending on your coverage. Apollo mine seems to be fine here,
After clearing data and caches, I flash the stock rom, restart normally, restart immediately into cwm recovery and flash the rom of my choice after clearing data and caches again, including the Dalvik cache. The stockB08.zip is the one to use for Unitology. I always restore manually from my TB backups and avoid restoring any system apps.
I hope this helps.![]()
