Root [Boost Mobile] [ROM][BASE]TweakNation 1.0.0GM {Released}
Will You Base Your ROM Off TweakNation?
  • Total voters
    13
chevanlol360
Android Expert
TweakNation's
THREAD NAVIGATION​
T1. TweakNation's Description & Features
T2. TweakNation's Change Log & Download Links
T3. TweakNation's Developer Section
What Is TweakNation?
TweakNation is a Stock ROM that i have built for the Warp Community that has been tweaked to the fullest and still has stock theme. TweakNation has over 25 amazing features over simple stock B08c for the Warp, but what is it that makes it so special? ANYONE can use it as the base of their ROM that they want to create.
Why Am I Doing This?
First off i think that it will help the Warp Community and the Awesome Dev's that they have here.
I also wanted to give the community back one last thing before i leave. Thats right i'll be leaving the Warp Community in a few weeks, I have been with you guys from day one and when i said i would make one of the best ROM's out there for this phone i wasn't lying:rolleyes:. Even Though i have never had the phone i still feel like i am apart of this community and its been one hell of a pleasure helping and creating things for you. I wish the best for you guys your all amazing.
Features:
Change Log Data:
Code:
[B][SIZE="3"][U]10/13/12 Version 1.0.0GM[/U][/SIZE][/B]
[B]■ Initial Release for Warp[/B]
Download Link
TweakNationCWM.zip
Installation Instructions
Disclaimer: YOUR WARRANTY IS NOW VOID Neither myself or my development partner are responsible for any damage you do to your phone. All of our files/development are always tested extensively by several testers. If you are not familiar with these methods, I'd suggest that you do some research elsewhere to better understand before you attempt anything on your device.
First backup all your apps and important files
■Download the zip file DO NOT UNZIP THE FILE
1. Boot into CWM.
2. Choose "Install Zip From SDcard"
3. select "Select Zip"
4. select Locate and find "TweakNationCWM1.0.0GM.zip"
5. confirm "YES - Install "
6. wait for script to finish
7. reboot phone
First boot could take up to 5 minutes, the reason is because the ROM is going through its first boot and loading all the needed files, data etc.
Developer's Section
Bugs:
Code:
None
Flashable zips for changes
RegularClock.zip
Removed Apps
Code:
[B][U]List[/U][/B]
Docoments To Go.apk
GenieWidget.apk
GlobalTime.apk
Gmail.apk
HTMLViewer.apk
Launcher2.apk
MagicSmokeWallpapers.apk
Maps.apk
NotesPad.apk
Protips.apk
stopwatch.apk
Street.apk
VoiceDialer.apk
VoiceSearch.apk
VpnServices.apk
YouTube.apk
Zone-Boost.apk
TWN 1.0.0GM "Un-flashable" Build
What i ask of you to do and not to do:
First off in the creation of your ROM, since your building off TweakNation i only ask 2 things of you.
1. Give Credit in the OP thread of your ROM
2. DO NOT Remove the TweakNation Splash screen, yes you can add whatever custom boot animation to the ROM but not the splash screen, at least not without my permission.
Thank You for respesting my wishes.
Well i tried to modify this to bring my rom up to B08c since i didn't feel like porting all the stuff i ported to begin with lol. But i cant seem to get away from errors when it comes to adding my theme so i might be staying on B08
Now this is what I'm talking about! Simple and not too much jazz! The notification bar is a little weird with the clock and notifications though. At any rate, thanks a ton Chevanlol360! I know this was meant more for devs, but this is the kind of rom I've been waiting for.
Looks good I like the boot images and everything overall but even over clocked it's slowing my phone down really bad. It's lags real bad. Not sure why. Anyone else have this issue?
I just reset my phone back to factory and reinstalled CWM and SU, I was using TB to backup all my apps but I think it's one of the apps that's causing me problems. So just going to take the long route and reinstall everything fresh and not restore the backups from TB and see what that does for me.
