Root [Boost Mobile] [ROM][BETA][4.1.2][Team Osiris] AOKP Jelly Bean for ZTE Warp 1/25/2014
ok so like skinny said works for small incoming pics but nothing large or anything going out seems to pick up the pictures on reboot
wat i mean is ill have someone send me a pic wait five mins and reboot phone.
pic instantly shows up in messages under a diff thread but same contact name
Does anyone know what settings to choose to get more battery life out of this rom? Battery seems to drain quickly. :(
Hmmm, turn brightness down, wi-fi off etc. Scale down the kernel to 61MHz/min, maybe run it at the high end around 15-1708Mhz/max. I have a few things turned off also, but I have the scrolling stuff set to light speed!! :D
ok so heres what i have for ya small pics in and out no prob large pics iffy still waiting on confrimation that mine sent but have recieved a few thanks lilbit for the fresh install tip
I am by no means qualified to give advice on this subject but I am pretty good at finding answers to things that bother me. lol
I looked at the xml file included in your apn.zip and the settings for boost mobile in it are not the same as the ones I could find online. Now don't get me wrong I am not saying they are wrong, just that I could not find those exact settings online.
All of the ones I found had an underscore between boost and mobile for apn name does that matter? Would a apn-conf.xml from a working boost phone that only has 3g be useful to solving this issue? I may be able to pull one from my daughters cell. She has an LG venice but I think it only has 3g also like our Warp so should have compatable apn settings?
Go for it
Alright that went well. Did a full system wipe and factory reset. Downloaded the rom the gapps and the apn on my pc then transferred to my warp. Flashed all three together just as lilbit did. Sending and receiving pictures, sideshows, and videos excellently. Only side effect is that the picture doesn't come up in the same conversation as the person I was texting. So I'm texting this person in one thread and the persons pics are coming thru a separate thread. So I click on the picture thread and reply with a regular text. Lol (here is the buggy part) that text reply went to both threads and started a third thread that was addressed to my own number lol so I ended up texting myself. It's OK if I keep the replys to the text in its own thread it only sends it to the person I want to send it to. But if I reply in the separate picture thread it sends to that person and me and back to the picture thread. Really weird. But all pix went through.
ok so I will pull that file from my daughters phone tomorrow, now for another newbie question.
If I want to replace the existing apn-conf.xml with the one from that phone providing it is not LTE and just a 3g like I think where would that file be on my phone?
Is the only copy in the etc folder? or is there more than one copy? The reason I ask this is because some of the files I have found online have a line in them saying the contents must match the apn-conf.xml that is in apps/something/something/something lol sorry I could not remember the full name off hand.
I just want to make sure that I place it in the correct place.
I tried the fix of simply rebooting into recovery, then wiping dalvik cache and battery stats. Since then, ive had no problems with the mic at all, although i havent tried using speakerphone.
