![CTBannerblank.png](http://i1086.photobucket.com/albums/j447/Bloodawn/CTMod/CTBannerblank.png)
CTMod is a minimalist ROM designed for speed, stability and usability
![ct380w_zps426c0c74.png](http://i1086.photobucket.com/albums/j447/Bloodawn/ct380w_zps426c0c74.png)
![CTFeatures1.png](http://i1086.photobucket.com/albums/j447/Bloodawn/CTFeatures1.png)
- Based on B10
- Kernel: Alien Kernel 3.0 modified by me for CT (unsecured, optimized mounting, init.d support)
- ClockworkMod Superuser
- Busybox
- adb enabled at boot
- deodex'd, zipaligned, optimized and debloated
- Fully themed
- 13 widget Quickpanel
- Swipe to clear for notifications
- Extended Power Menu with Screenshot, Reboot, Fast Boot and Recovery
- Downloadclutch
- Adblock
- and more
Added apps:
Installation will wipe all Data and Settings
Installation:
➯ Copy the zip to your sdcard
➯ Boot into CWM or TWRP
➯ Make a backup!
➯ Select "install zip from sdcard"
➯ Select the ROM.zip
➯ Select "yes"
➯ After its finished press back
➯ Select "reboot system now"
![](https://www.paypalobjects.com/en_US/i/btn/btn_donate_LG.gif)
Downloads:
CT3.80_N860.zip
Code:
[center]MD5sum: 7057f2c9eafd84d67fbe555ce1802b8a[/center]
Old Versions:
CT3.75-Final-Warp.zip
Code:
[B][SIZE="3"]Changelog:[/SIZE][/B]
[B]04/11/13 Version 3.80[/B]
Upgraded base to B10
Upgraded kernel to Alien Kernel 3.0 and modified the ramdisk for CT (unsecured, optimized mounting, changed how init.d is done)
Fixed SystemUI bugs (so it works with UOT)
Fixed downloading text color
Rebuilt CTSettings (fixed some bugs and added CPU, I/O and Swap Control to it)
Removed Boat Browser, stock Clock and SuperSU
Added Lightning Browser, MiClock and CWM Superuser
Updated gapps (fixed YouTube issues)
Updated File Explorer and QuickPic
Updated Busybox
Updated some of the theme
Updated font
Enabled CRT effect
New Settings layout
New boot animation
Ported swipe to clear for notifications
Ported animations from JB 4.2.2
Cleaned build.prop and init scripts
Performance and stability improvements
[B]12/10/12 Version 3.75[/B]
Fixed the Alarm Clock app
Fixed notifcation transparency
Added the ext4check.sh mod I forgot to include last release
Removed the Flashlight widget since it doesn't work
Redid the Power Menu and added Hot Boot
Updated Play Store, Xperia, File Explorer, Quickpic and SuperSU to newest versions
Switched from Chrome to Boat Browser
New loading bar
New wallpaper
New boot animation
New wifi icon
New Settings layout
Removed Update Firmware and ZTE Update from About phone > System updates since they won't work with CT
Since this phone pisses me off I removed Voltage Control, switched back to the stock unsecured kernel, removed all init.d scripts and almost every build.prop tweak. you guys can flash whatever kernel and do the mods you want.
[B]10/7/12 Hotfix[/B]
Fixed for notification transparency
Added data fix since I forgot to include it in the rom
[B]10/7/12 Verson 3.68[/B]
Initial release for the Warp
