Just flashed so far loving it very smooth i did use tb for a couple restores i know i shouldnt have but ill use trial and error bit awsome rom and had a laugh at chicken tit didnt know thats what ct was for
I may have missed it but what can i do to make the camera work it didnt evwn work after fresh install
the color changing is normal yes, and I just downloaded/installed holo without a problem.
you didn't restore anything after flashing the rom did you? I forgot to mention not to restore any data/apps from any other roms or it breaks shit.
Use ICS Camera Free It Woks Perfect....
My Question????? Why I Cant Download Instagram From The Market, It Say Not Compatible With My Warp???
Coming from the prevail? Yes. Well worth it. I did it myself as my wife and I had the prevail and upgraded.
Battery life is decent but not the best. I'd advise hitting up ebay or amazon and getting an extended battery set for like 10 bucks.
2180mAh AceSoft Battery+Charger+Suction Stand Holder For ZTE Warp N860 Accessory | eBay
Hey does anyone else have a problem with the alarm clock not working? It gives me the force close error when its due to go off.
OK question, got my free warp phone from my friend, but it's rooted.
Which way is the best to activate the phone to my account? or how do i go back to stock?
Best way to activate it is by calling boost and giving them the info from your phone. The MEID number. Be sure not to call from the warp.
If you want to go back to stock rooted or non I can post you a link in a minute. Are you currently running a ROM? CTMOD as you already know doesn't have the hidden menus. So you will have to flash back to stock before getting your phone activated.
Lets make another thread as to not clog up bloods.
Has anyone been able to update Google Play to 3.9.16. Im currently running 3.5.15. I have tried all the usual ways, clear cache fix permissions ect.
Love this Rom
