Root [Boost Mobile] [ROM] Halo ROM V.1.1 B10G (updated)
What color highlights would you like to see?
  • Holo blue
    Votes: 4 44.4%
  • Transparent (ie none- static b/w)
    Votes: 3 33.3%
  • Keep it the way it is (purple)
    Votes: 0 0.0%
  • Green
    Votes: 0 0.0%
  • White outlining boxes over black
    Votes: 2 22.2%
  • Total voters
    9
  • Poll closed .
Status
Not open for further replies.
Yes most definitely, if I remember correctly according to an earlier post that BLVCKHVLO made, its already in the rom but its not in the setting menu yet. I'll add it in ASAP and release an update :)
This is my everyday rom and I love it! I have no problems except the occasionally reboot while playing games and running out of RAM, but overall my favourite.
Fast, stable and good looking! :D
I know I'm having the same issue with the ram, I'll see what I can do about that....
Anything you guy would like to see in this rom apart from tethering? Would you guys like if I put my theme into this?
I'm still gonna make sure that people know that this is BLVCKHVLO's work and I'm really just helping him move it along...
Anyone like the name Halo Jelly or Ice Cream Halo? I have ideas for different platlogos for both (platlogo.jpg, when you tap on android version repeatedly this image pops up, for those that didn't know ;))
I like current theme too, can We have that option, an app to select/switch current theme with others ?
... and Adreno of course.
If you're talking about the CM theme Chooser, no, but I can try and think of something.... maybe like in setting menu an option with themes which reboots into recovery and automatically flashes the new theme upon selection then restarts the device. Its a little far fetched but I'm sure with enough reading I can make something that goes along those lines...
Sounds good:)
I'm not doing it for the next update though, I have to make sure that if I make it, that it comes our right and doesn't mess with anything else... and I'm certain there will be some smali to it...
Hey Skinny, I know you will do great with this rom. I'm sure BLVCKHVLO could not have made a better choice in who to hand this over to. If you need any testing I'm pretty much free til Mon.:)
Thanks guys and if I don't go to work tomorrow I'll start working some more on adding in the adreno tweaks and such. Shouldn't take too long though.
If I do end up being able to make the "theme Chooser" for this rom, I'm certain that TWRP would be the only recovery that would be compatible with it, TWRP has the openrecovery script (I think that's what its called), anyone know if CWM has openrecovery?
I dont think CWM has it. I have been using TWRP again for a while now. It's easier.:)
Then I'll get right on a 1.5 release immediately! :D
Just as soon as I can figure out how the hell I did this carrier logo in the status bar...
Status
