Skinnyjeans21
Android Expert
Lucky patcher
Lucky patcher
And everyone always assumes that app has no good, valid use... conversations have been shut down for just mentioning its name
Truly remarkable Rom one of my favorites the only thing that makes it freeze at times is when I'm taking a picture on instagram maybe its because I used link2sd? And put it to my sd? That's the only thing that I'm having trouble with.
Any file manager can handle "copy.com" ?
I use ES File Explorer to handle dropbox, google drive, etc, but doesn't support Copy.
Not sure which file managers support Copy, I don't manage from my phone, I keep everything on my laptop and manage from there. I'd use dropbox since its more supported but it doesn't meet my space requirements.... I have 60 gigs (and more once everyone confirms their emails, should be another 50 gigs) on Copy, they're super generous with space
Not sure what you want to do but try x-plore, it is in my opinion the best for cloud storage.
Wow 60 gigs going on 110? That's quite a lot!
tried x-plore, doesn't support copy yet
Copy have an Android client that works well on our warps, but I prefer to handle all with just a file manager like ES.
Yes, that is most likely the cause, some apps do that when you move them to the SD card using link2sd like the Facebook app it breaks of you use link2sd on it. They're really supposed to go in internal memory. Never figured out why they break though.
EDIT: you shouldn't have to move apps to the SD card, unless you've got this phone THAT loaded with apps, but it has plenty of internal memory its better to keep all your apps on internal memory because they load faster that way and they don't stop working if you pull your SD out or mount it in a computer.
Doesn't happen to me, how did you go about downloading the rom? Some things break if you use mobile data.
the way i downloaded was through my phone but i had wifi on. ill try to see if downloading it from the computer will do the trick. my internet sucks and is slow lol so ill do it from my friends internet speed ill report back as soon as possible thank you skinnyjeans!
I'll be honest, I love the idea of DPI settings in Halo like DroidSmith, but first I'd need to check out how it works. Changing DPI can break the Play Store. Also, its something that makes DS unique, so it wouldn't be right anyways. Sorry kdraw...
I think most Devs take it as a compliment when you use parts from their work, but there is nothing wrong with the way you feel about that.
Im perfectly ok with you using it. I haven't noticed any ill effects with the market either. If I wanted to try and hide the secrets of DroidSmith then most roms wouldn't have wifi tether, and the rest of you would not have provided me the help with the rest of the rom.
The dpi changer wasn't my work anyway. I just fixed it so that it worked with the warp without error messages
Some do, and some don't. I believe that sharing our progress speeds up development, because It allows devs to focus on new features rather than recreate something that is already been done. Some devs have copyrights on there work and make money on it.
Yep, the whole point is not only to make cool software, but to foster an environment where everyone can learn how to do all the gee-whizzy things we've done here.
I dont mind others porting my theme over as long as I'm given proper credit for it. Besides its all in the name of open source right? And all this is kinda what we're trying to do with alliance anyways
