rickpcb
The fix is in 6.12. And I can't see the images you posted rickpcb
Dammit tapatalk
Cool. Strange ya can't see them. I did add them as attachments, not link them to hosted files.
Dammit tapatalk
Just saw them from web view, nice benchwhat were your settings? Default?
For now. Just loaded up with apps. Gonna change it up tomorrow... wanna see how this works and check battery life.
HB 6.13 added to testing section, contains optimized pngs so the rom is a bit smaller now. There may be instabilities though so have a nandroid ready.
So far, so good. I downloaded all of my apps from Playstore (again). Running nicely though. Very Snappy!
OOps, gotta fix Voice search! I gotta have That!!!
Just flashed 6.12 - Running super smooth and fast. Haven't tried MMS yet. If it is a problem I'll just pull the old apk from the last version so I don't have to reinstall everything again...
I had trouble sending mms in 6 and tried it in 6. 12 and still won't send :-(
That helps a WHOOOOOOOOOOOOLE BUNCH thanks! 6.15 coming up, just added the new systemUI to 6.12. If this works then I'll release as an update.
BTW, I've decided to upgrade to the SGSII. But, I won't develop anything for the SII, nothing at all. I'm keeping the Warp I have to continue developing for this community.
I might get a SII you should port your Rom in your spare time
I'm on 6.12 and mms works 4 me sending and receiving
Same here!!! No problems sending or receiving with this version.
And same here. No problems at all sending/receiving.
