Root [Boost Mobile] [ROM] wrap 1.0
anthony062991
Hello everyone,
I do not own a ZTE wrap, so I can not test this!
I am not a Dev!
I thought I make a ROM to get you guys started!
BIG THANKS TO Woodstock77 FOR STOCK NANDROID BACKUP!
BIG THANKS TO JBrd400 FOR TESTING THINGS OUT!
Please test and leave as much feedback as possible!
Introducing:
wrap 1.0
Changlog:
based off of stock rom
init.d script enabled
unsecured boot.img
replaced default launcher with go launcher
a bunch of build.prop tweaks added
sdcard speed reader
overclock script to 1.4GHZ as default
(do not use any cpu app because it is not needed and it will show stock)
governor set to Performance for speed
Should be super fast and stable
some other tweaks I don't remember...
How to install:
IMPORTANT:
MAKE A NANDROID BACKUP!
I AM NOT RESPONSIBLE IF ANYTHING GOES WRONG!
MAKE A NANDROID BACKUP!!
UNZIP wrap.zip copy it to clockworkmod/backup
(do not rename anything)
boot into clockworkmod
-wipe data/factory reset
-wipe cache partitions
-system restore
wrap
You should have absolute no issues installing this!
The first boot could take up to 5-10min!
Please be patient!
Download:
http://www.mediafire.com/?yfwl980t5mf436f
(please do not mirror my links)
Feel free to donate to further my education!
"The file link that you requested is not valid."
Link doesn't work
Second link did not download for me.
I am downloading from 1st one right now.
Update: Link deleted because author request.
Anybody brave enough to test this lol? Says hes added overclock (must be done with a custom kernel right?) But hes claims not to be a Dev, Im not bashing you btw, Im just skeptical that this will work on our phones as he says he has no Warp to test this on and from what i know overclock=custom kernel....i am off to work but i may test this tonight when i have time.
+1, this is my working phone, so must wait some one confirming... I want to play but cannt
I used cwm and it gave me an error message. Sorry I didn't write it down. I wanted to restore my backup as soon as i could. This is my only phone. You can try it and check the results and then just restore your backup. Cwm worked beautifully. Wish i was more help but all the error messages are still greek to me.
Thanks, thats clearer, i figured thats what happened. I may test tonight but figured it wouldnt work, ill see what error msg we get and report back this evening. gotta have my phone for work lol.
i tried installing it also , & i got this error message
Installing update...
assert failed: write_raw_image("/tmp/boot.img".
E:Error in /scard/warp.zip
(Status 7)
Installation aborted.
CWM did restore all your data ok ? or youur settings, etc were lost?
Good to see someone else working on this stuff. Here is the partition info that QuietStorm provided us with. Note: Warp uses emmc, not mta. I haven't been able to validate all of it, but I'm pretty sure it's good. I can help you with boot & system if you still need those too. Just PM me.
# mount point fstype device [device2]
/boot emmc /dev/block/mmcblk0p12
/recovery emmc /dev/block/mmcblk0p13
/splash emmc /dev/block/mmcblk0p14
/system ext4 /dev/block/mmcblk0p15
/misc emmc /dev/block/mmcblk0p16
/cache ext4 /dev/block/mmcblk0p17
/data ext4 /dev/block/mmcblk0p18
/sdcard vfat /dev/block/mmcblk1p1
Yes, I need you to pull /boot emmc /dev/block/mmcblk0p12 and /system ext4 /dev/block/mmcblk0p15 for me if you can and upload them.
