when it comes to the little green android it says waiting for devices i am using windows 7 64 bit
Rom manager is a bad idea. The ZTE Warp is not supported by it. That app bricks more phones than your local recycling center.Hey Guys;
Thanks for all the hard work that you have put in to make this a reality! I just had one question can I use Rom Manager or is that a bad Idea? I did install it and when you click on "download rom" it says you have to install clockworkmod recovery installed before continuing. Is it a bad idea to install from Rom Manager!
Yes but people have said how to install your drivers many times. When the phone reboots to the green android go to device manager and look for the device with an error indication then right click it and choose update drivers. Then choose have windows find the correct driver for you. Good luck.Is any else having problems with windows 7 64 bit
I'm having trouble getting CWM installed, but I have the ZTE drivers installed.
I run the oneclick install and I get errors. Here is a screenshot of the issues I'm having.
Try this one.
That one worked, ThanksTry this one.
I'm having the same issues. Why exactly do the drivers need to be updated? Sorry. I like everyone came from the prevail, and it was easy because of odin. Is there some way a program could be created to flash images? I'm a noon so school me
When that happens and your about ready to throw your Warp in a trash can try a different usb port. Trust me mine didnt like the front ports and had to plug it into the back.the main issue at the moment is that it will not find the correct android drivers after it gets to bootload screen. in the device manager it shows the yellow ? next to android, drivers wont update, cant roll back cuz it says none installed, tried all variations and different ways to auto update and manual update of the drivers, included the ones posted. if i try to continue, it fails to load recovery.img....... the issue is the drivers, adb recognizes the device, just wont go further...
