Root [Boost Mobile] shutting off
hey peoples ... i woke up this mornign and phone was hot ... now it shuts off in sleep mode and i have to take battery out ... phone is completely stock ... how or can i fix this
Mine had a lot of reboot and heat issues when ii first got mine and it was stock it wasnt solved untill ii rooted.but thats just me
Rooting more or less is what a plant does to stay in ground.
I kid.
Rooting your phone gives you administrative rights. It allows you to delete apps, and install a custom recovery and new roms.
also as long as the phone isnt on the charger it will wake up but if its in sleep mode it will not turn on if not on charger
Guys,
Hope you all don't mind, but since the thread's take a bit of a root-related turn, I'm gonna move it to the all-things-root forum for you.
getmoney06, if you decide that you don't want to go the rooting route and would like the thread to be moved back to the general ZTE Warp forum, just let me know.
Cheers and good luck with your device's issues--lots of great folks like the above are here to help and advise you (but be sure you know what you're getting into if you root--it might void your warranty).
