I have been flashing back and fourth between WarpOEM and this ever since this ROM began. The latest test build (8) is by far the best. Here are the following noteworthy points:
Pros: Bluetooth works (only) with my lg stereo headset and my ELM adapter in my Ford Escape (Bonus... this was my main requirement).
WiFi still has dhcp laziness ;-) however using WiFi Static w/ force apply enabled works 100%. The other nice thing w/ this app is it keeps separate IP profiles based on said and Mac. After checking memory logs ram seems to be better used (less room issues and purged assets). Also Ramexpander worked on all versions of this ROM however when using /data as swap location previous versions averaged 2 to 4 Mb/s and this version averages 9 to 12 Mb/s for internal and 8Mb/s on class 10 SD.
Finally a few of my favorite games work well on this version only ( Real Racing 3, Gunship III, and GTA is finally playable.
Cons (or unresolved issues): still can't use sd-ext (is this a hardware issue?).
Battery life is way shorter (however only done 2 full cycles).
GPS has attitude (similar to woem) . Seems changing server to NTP from xtra and reboot helps prevent GPS turning off.
Let me know if you need any specific details and awesome job!!!
