LilBit
Extreme Android User
Yep. I was trying to make sure that one of the new icons matched the color of the others.
What do you think?
Is it too light?
Looks perfect on my laptop screen.
An exact match.
What do you think?
Is it too light?
An exact match.
Thanks Lilbit!
I'm trying to make the stock mms app look more appealing because I'm getting pretty sick of go. I HATE always having to switch from go sms to stock whenever I want to send a picture message.
Ah man that sucks that go's doing that to ya. I haven't had that problem. Freaking ZTE and their horrible QA standards. I'm excited to see what you do to stock though, I'll drop go too![]()
Looks perfect on my laptop screen.An exact match.
I just re- flashed it. Good Job!
Can you try it on a low brightness setting? I think it matches on high brightness, but not on low.
The noob version with animations looks great, low light as well. Another great job i2f, imho!!
thanks sooooo much for these flashable themes!!!
God these flashable themes saved me just now! I tried editing some XMLs and I was certain I did everything correctly but apparently not because I got stuck in a bootloop. I didn't have space on my sd card to move my nandroid backup (I couldn't find it in my computer anyways I couldn't remember where I put the file) so I remembered these themes you made. I flashed and it fixed the bootloop!thanks sooooo much for these flashable themes!!!
I don't know if I flashed correctly... Is the Noob vesrion supposed to be solid as opposed to the CT which is a more transparent black? I really like the CT one better. Is there a version I can download to get the same look?
I'm not exactly sure what you're talking about. What part of the theme are you talking about?
I found a new set of battery icons and I'm not sure if I should use them. I will create and upload zips tonight.
