HawgHunter
I don't know if it will help you in the investigation of the Swype keyboard but I tried to install the Go Keyboard that I've used before on the Warp, Galaxy Prevail, and an HTC Incredible. With the Go Keyboard I can't even get the check box to stick in the Settings->Lang & Keyboard section. Also, the Go Keyboard doesn't even show in the input select popup when you long press an input field. I hope some of this might help provide insight into the cause of the trouble with the Swype keyboard.
Again, thank you for the help.
EDIT: After restarting the phone the Go Keyboard was checked in the Settings->Lang & Keyboard section and it showed in the input select popup box but the Swype keyboard did not. It appears that only one other keyboard can be listed in the input select box. I hope this info is helpful.
) if i need anything ill definatly let you know thank you for offering
