galaxyesm
You can't use a nandroid but you can use titanium backup...
Sent from my N860 using Tapatalk 2 Beta-5
Thats what i mean like a titanium backup lol.
Thank you for the quick update, I really appreciate it.![]()
I'd like to get into developing stuff like this, are there any tutorials out there on this? Where did you learn/start?
I've only had it loaded for a day but, so far, I've been very pleased with it. I understand it's in development and I will participate in testing and feedback if you want more people to help.
Keep up the good work.I've been wanting ICS for the Warp since I got it last December. I ran across this version while looking for a stock ROM to fix a boot loop problem. I'm thankful that my phone broke.I've only had it loaded for a day but, so far, I've been very pleased with it. I understand it's in development and I will participate in testing and feedback if you want more people to help.
The only problem I've found so far is that the Play Store says the Netflix app isn't compatible with my phone whereas on Gingerbread it was running fine. Did I do something wrong or is it a bug?
Thank you for your effort. As an old software developer I know the hard work and the joy of success. You should have a lot of joy now.Keep up the good work.
For anyone having troubles with the market flash this: http://db.tt/Yvhmk18C
It will erase your data but you can backup all apps with titanium backup... DO NOT USE NANDROID TO RESTORE DATA OR THIS WILL NOT WORK...
Oh, yea! Works great. Thanks a bunch for letting me know what to do so quicly. I didn't realize it would fix that problem when I applied it earlier. I just hadn't retested it before I made my post. I've caught up with the thread now.It was my fault... I made a fix which you will see below... I'm glad that you like my work
B01 is the baseband , B08c is the software versionI wonder if changing the baseband N860B08c to N860B01 is something I did inadvertenly or was it in the image like that? Does the image even affect the baseband setting? I will appreciate enlightenment and, perhaps, some guidance to get it back to N860B08c if it's possible. Thanks.
:stupido2:
I try my best... lol... Its not like I have much else to do... however just a heads up... football workouts have started so I won't be as active on here when I start going... they're from 4-8 eastern time and after practice I usually crash sooo... to sum things up... less updates unfortunately :'(
I have found that the Sense Analog Glass Clock is FC'ing when I tap on the button for "Skins Individual Browser and Downloader" in settings for the clock. Any idea of why it is happening? :hmmmm2:
Will anything happen if I delete dolphin HD? I want to replace it with boat browser
Just to let you guys know I have also received dev status and have a sub forum in the custom roms section
http://androidforums.com/showthread.php?t=570896
How would one delete the Dolphin HD browser? I didn't see an uninstall option in the applications management section in settings. I haven't tried it yet but I suspect one could simply load another browser and select the one you want when the system asks which is the default. If you try it, please let me know if it works. Thanks.
Two new things today for this old dog. Thanks for the guidance.![]()
