StarScream2109
Extreme Android User
Hope that helps buddy let me know
So just a quick question; Anyone have the gtalk APK? I've tried two different ones from two different roms for the warp and none of them install; Which makes me wonder why its not on the google market o.o...
Have you noticed a difference jet
Yeah the audio is off the charts now and its not distorted... thanks man
Sent from my N860 using Tapatalk 2 Beta-5
just put my name up so everyone knows
Haha no problem brojust put my name up so everyone knows
I just gave you the xloud i feel that should suffice for your audio if theres any request for the beats+megabass let me know![]()
I would like to try the xloud if possible
Replace the build.prop with this one: http://db.tt/hJ6tmhZR
Love the dpi, just that little bit extra screen space makes all the difference![]()
i just flashed the file that was sent and the beats audioUse root explorer and there's a file there called build.prop in system (I think that's the right spot ) replace with the one jet posted and reboot. I think you should reboot anyway.
Edit: typo. Fixed.
How i replace it? I just downloaded the build.prop file. But i havent try the v.1.0.1b yet. Just in case.
Just use root explorer to copy and paste it into /system
Copy and paste should overwrite it
so look at my rom thanks
