Root [Boost Mobile] Warp Cream Sandwich Rom [Discontinued]
Should this rom move away from Ice Cream Sandwich and Towards Jelly Bean?
  • Yes
    Votes: 146 83.9%
  • No
    Votes: 28 16.1%
  • Total voters
    174
I go to B08c from apollos thread then...i boot that stock..then i go to CWM then i go into install from SD then i chose the file...i boot it up...then i go back to recovery? CWM? After that i install update then tthe beats then clear devch? Is that right or am.i wrong? Lol...maybe u guys are right >.<
I've been bug fixing all day trying to fix an issue with the next update... I done these steps all day long with no issue...
Flash v1.0
Reboot
Flash minor update
Reboot
Flash beats audio
Reboot
Reflash kernel (Its at the bottom of the OP)
I've had no issues with those steps so far
Sent from my N860 using Tapatalk 2 Beta-5
Flash v1.0
Reboot
Flash minor update
Reboot
Flash beats audio
Reboot
Ok ill try that one...and is it called "Stock Kernel?
I'm currently testing V1.0.1b... It includes all previous updates including a few bug fixes so if you still have problems don't worry
Released new update... checkout the change log for info
Brooo...i think i found my problem...i did everything u told me...and once i get to the step.were i have to install the beats file after that it wont let me use my cameral...what does file actually do? And how do i install v.1.0b?
1.0.1b has all of the previous updates plus bug fixes and themed signal bars... I also changed the dpi (resolution)... just flash it in cwm...
Okay i follow all the steps? would there b something wrong if i dnt install the beats file? And i only install the rest of the files even the stock kernel? Then after that i install the v1.0.1b?
You can install 1.0.1b by itself... its an entire rom and includes the other updates
Okay thanks just downloading the file already...one question...why did u delete the batery icon thing >.< i liked it lol.
rom perfect man good job. Dropbox is not compatible with this rom not worry I have the apk:thumbup:
Its because I changed the rom name in the build.prop... im going to change it back in the next update to avoid this problem
I want it to look as close to stock ice cream sandwich as possible
I have all the apk of ics and I have installed and work perfect man but for others it would be good for now so I stay with this rom
