Is it still giving you problems with the market?
Have you tried the 1.0.1b? Its odd that your the only one having problems... or the only one speaking upNoo with everythinf...i was using titanium and it close it self and send me to the home screen then i would try again and it would do the same...after that it wouldnt even let me go to the app drawer ill just turn black and send me back to the home screen -_- i like how it looks and all but it just doesnt let me keep it :s wahh.
Sent from my N860 using Tapatalk 2 Beta-5
Thats the file im using the 1.0.1b...and yeah it just doesnt like me at all :s...maybe but idk just a maybe...its cuz im on unitology and i just flash B08c then i install the 1.0.1b...then injust start using everything..
Did you clear dalvik and cache before installing?
Flash to stock and then this time before you flash my rom clear cache and dalvik
Ohhh also...hmm...do u guys know of a good battery percent app that shows how much battery I have in percent?
Just search battery indicatorhope that helps
as for me thats the one i use haha its just called battery indicator
My play store only shows like 12 apps. And they don't show up when I search either.
Its because of the lcd density
OK... I've made a fix but you will lose all your data... :'( Ill upload it in a few
I assume apps and whatnot
Cant they just be back-up.?
