jetx2x
Android Expert
I've loaded the nandroid backup and so far everything is working fine except for the Wifi which connects to my local network and is pingable but will not connect to the internet. It loaded easily and it is the cleanest look I've seen on a ROM so far. This is a very good ROM from a user's standpoint. I really like the way jetx2x cleaned it up. Thanks for the hard work, jetx2x.![]()
have you tried restarting after you turn on wifi? Mine will connect with data but if I turn it off and back on then it will not connect... but then after a reboot everything is fine
Sent from my N860 using Tapatalk 2 Beta-5
