Root [Boost Mobile] Warp Cream Sandwich Rom [Discontinued]
Should this rom move away from Ice Cream Sandwich and Towards Jelly Bean?
  • Yes
    Votes: 146 83.9%
  • No
    Votes: 28 16.1%
  • Total voters
    174
Initial flash things seem to work well. As I expected the new beats drivers did cause a fc for volume+, Hawg may be able to confirm this. I also couldn't get meatballs free to open. The only other thing I noticed is that inside the settings menu the option to turn on WiFi does not work. It will come on with the power control widget and through the normal settings menu but not the switch you added. Understand that?
All in all so far seems to run smooth. I love the changes.
I flashed the new release a little while ago. It installed without any trouble and I've had no trouble with my apps except for Volume+ FC'ing. So far, I'm not missing Volume+ because the app with which it helped the most is loud enough for me to hear it on this ROM now. I assume this update made some changes in audio drivers.
The only other problem I'm having isn't related to this update. I've had it since flashing 1.5. I can't seem to get the File Explorer to update. I download the file to which the link takes me and it tries to install but says "Not Installed" on the final screen and the update reminders start again. What can I do to update to get rid of the reminders? Thanks.
I love this ROM. It's sleek, crisp, and responsive. Good job, jetx2x, good job. What's next? :)
I'll keep putting it through the paces and report my findings. Thanks for the opportunity to evaluate this update.
PS: The wifi will turn on and off in the settings menu, but not in the first level. You have to choose "more" and use that wifi toggle. :) Or use a widget. :)
The check marks on the settings menu will not work because I haven't coded them yet... its part of the reason why I had to delay the update... as soon as I figure out how to code them I will release another update...
Sent from my N860 using Tapatalk 2 Beta-5
The increment is 1 and Im considering adding in the numbers... and I will see if I can remove the update notification from file explorer... it seems to give the notification even if it is up to date
I found one in my ROM Toolbox Pro that is cyan color with a thin indicator bar on the bottom of fairly large numbers indicating the charge level. When it reaches 100% it says "FULL". It's much easier for my old eyes to read. :)
I cant wait! :D
Is that fix you posted the same fix from your first post?
So really, the only issues I've seen is two live wallpapers force close... Those being metaball and color twist... Others seem to work... Other than that you've done a great job man. Outstanding look and feel to it.
Just clear cache and dalvik
thanks for all the hard work i have tried out nearly all the roms available on here for b08c and on the net that i could locate and this is by far the best one !!keep up the good work.
ok just flashed it but when it installed i did not see anything it usually scrolls what it installs but this just said extracting files then said done reboot did it install correctly?
