Marty_Since87
Android Expert
I'm fixing up the settings menu but somethings wrong... as soon as I fix the fcs I'm getting it'll be ready for testing... btw I have decided that in order to prevent all kinds of eff ups and giving myself a headache.... this version will erase all data....
Sent from my N860 using Tapatalk 2 Beta-5
Ok, I'll back my data up just in case I'm chosen to test.
I'm sure jetx2x won't mind you trying another rom. I suggest you clear data and the dalvik cache then flash stockb08c.zip. Start normally and then immediately shut down and restart in cwm recovery to clear data and Dalvik cache again. Then flash the Win7 rom. I always clear the cache and the Dalvik cache again just for the heck of it.I usually run Fix Permissions and start the phone in the new rom. I hope this helps.
PS: The reason for flashing the stock image is to make sure the phone is in a state that the new rom will "recognize". It has all the stock settings from which changes where made to develop the new ROM.![]()
So if I'm chosen to test out the beta, all I have to do is "clear data and the dalvik cache then flash the beta zipfile?" I wouldn't have to do anything else?
