Root [Boost Mobile] Working Flashlight Fix
You can also download RootDim. It lets you control all of the lights and lower your backlight than it can go normally. Once you download, go to other lights, select flashlight, then select on. You can always put things back to normal by selecting system default. BTW, i heard a widget is in progress also because the current one shows on some phones and not others.
Yea but there's no substitute for a flashlight app with widget...
