What?? Where did you get that from?what is PEREGRINE S DRIVER?
Ok, seemed to work fine when I was on 4.3 a while back. Didn't have any problems at all.Twrp doesn't with right with this phone. You're best off using Philz.
Why not look in that section?The phone is xt1042 moto g 4g
Now its boot looping . Then i found out twrp fail to make a good back up of the stock rom....does anyone know some good roms for this phone
i found resolvement im on the carbon now and with twrp touch. works great. Thank you guys anyways.Why not look in that section?
Sorry brutha I'am just now seeing your message on here I could have helped you on this topic.Does anyone know what the latest TWRP for the Sph l710 not the t model is? I see the spr for sprint but not d2lte. On boost, I used Twrp on the prevail and this s3 about a year ago but was thinking about trying again. Had no problems with the old Twrp when using it.
i must say i been running wicked s5 full exp n it is seriously stable n clean n packed with with great features. Totaly agree biker awesome work...Hello guys and gals. I just wanted to let everyone know that bilgerryan has released a Barebones version of his Wicked S5 Xperience ROM. He's removed approximately 100mbs from the full build. I've been running it since it's release and it's running GREAT! Battery life is great and for some reason both the full build and Barebones have better signal strength than other ROMs too. If you want to try a great ROM then give the Wicked S5 Xperience Barebones build a try. If you want all the bells and whistles, give the full build a try. Both are excellent.
Here's a link to the Wicked S5 Xperience Barebones build. If it doesn't take you directly to his post with the link just scroll up or down a few post and it'll be there. You can go to the OP to get the extras for the build.
http://forum.xda-developers.com/showthread.php?p=59620906
HAPPY FLASHING!![]()
No probably not, did you wipe all data on internal sd, meaning everything, songs ect? You have to when switching from lollypop to back. You need to keep backups on external, when you wipe you will loose them if on internal.Well it was rinning great till i messed up n installed liquid smooth LP 5.0 n now some how lost my 4g as a result any idea what happened oh also now i cant get any other roms to install on mg phone but lucky enough for .me i had a bkup of wicked not wicked x or s5 expirence . I tried formating as requested by madbat suggested from an earlier post. I get same resilts... is it posible that my internal sd crapping out on me as to flashing to much...?
Are you doing format /data and /data/media (/sdcard)?Thank u good sir for responding back.
I did a bkup of everything and saved it to my computer. Then i did a wipe data to install new rom . Wipe dalvik cache. Then manufacture reset. Then format internal sd. Then intall Lp liquid smooth 5.0 it installed but i lost data services. Then i did everything again and tried installing wicked s5 full n it craps out with error "system cannot unmount" no such file or directory....![]()
Why not mounting, no clue. One time I had to flash the apn fix, only once though.Corrrect at first i formated the 0 directory than i went back n formated data media
