I just noticed on Moar, I started with stock kernel, then switched to the other dkp kernel and noticed it used 2 gig more of the internal storage. I was like oh well and couldn't see why I had 2 gig more used. I switched back to the stock and now have gained that 2 back again. That explains that, seems like alot for a kernel. But didn't know if anyone else noticed that too.
Does seem like a lot. Not sure about that. You are used to worrying about storage from the Prevail. That is a good thing. I guess when you get an S3 you get a little lazy about that.
I have never had a storage problem on the S3. But I don't understand why a kernel would use that much space.
Guys. Get rid of MOAR if you're having issues. There are too many ROMs out there that run great.
If you want TouchWiz then go with Wicked Sensations.
If you want AOSP then go with CM11 or Carbon.
I suggest any of the above because I've ran them. The only issue I had was with Carbon and it looks like Struckn has a camera fix in the Carbon thread.![]()
I seem to be having some issue with call quality on moar. It's hard to understand them at times. It's not the modem because it works fine in stock tw roms. It's more a kind garbled or muffled in a way, it's hard to explain really.
I've seen some mention the call quality but never saw anything really in depth.
I'd really hate to stop using it, but it's almost to the point of not being usable at this point.
I don't get a lot of calls normally but today I did and it was noticeably bad and I had to keep saying stuff like "huh?" And "repeat that" quite a bit.
So is there a way to clear the call quality up at all?
Forgot to mention, this also does not happen in aosp roms either
Only reason right now I'm going with tw is a game I'm currently into, subway surfer.
So quick question about wicked, the color scheme, can that be changed?
I in no way am saying it's a bad rom, just not a huge fan of the color schemes they currently have out for these tw roms, as well as the fancy different icons they use ie: toggle icons.....I prefer the stock look.
I didn't care much for the all blue with wicked, so I went with the Eredicate theme. Much better in my opinion. Also, gurple is being worked on, so that might be another option in the future.
Wicked also has Xposed Framework installed with the Wanam app. A lot of stuff can be done to it to theme it up.
Yes. There are 3 or 4 themes right now and more being worked on.Wicked also has Xposed Framework installed with the Wanam app. A lot of stuff can be done to it to theme it up.
Hopefully Gurple will be done soon.![]()
snow storm hit here pretty good. i flashed the wicked sensations rom and must admit its a very good rom. hey biker can it see me lol. so far im loving it. its quite snappy without any overclocking. all that i tested worked. i new it would from your reports. i can only add that otg works fine. i believe this will be a daily driver.
Left ya a PM
All I can say is Wow! This could be a huge update for us, guys!
Philz just updated his recovery for the d2spr to fix most of the status 7 problems that we have.
If this works, we won't have to remove the asserts anymore. We can flash the zip right after download.
He just posted this and I can't get the download to work yet. Let me know if anyone does.
[d2spr][CWM ADV.] OFFICIAL PhilZ-Touch Recovery 6.12.8 [1.30.14] - xda-developers
Edit
Got it installed. Did not work for me. Still get the status 7.
But, at least Phil is working on it. Maybe someone else will have better luck.
It had been a while since I updated my recovery. Looks like Phil has added some things...
The assert override Phil included only bypasses the bootloader asserts, it doesn't bypass the device check, which is the first line in the current updater-script.
Ahhhh! What would devs have to do in their asserts to fix this for Boost and Virgin Mobile?
If you look at the first line in the updater-script it looks for "d2spr" so it would need "d2vmu" to be allowable for VM, I don't know what designation Boost uses.
All they would have to do to get it to flash on our Boost phone is to add our Baseband. That's what I was originally doing before I started removing all the asserts altogether. I've added my Boost Baseband to several of the AOSP updater-scripts and flashed the ROM.![]()
