Well, so far this is turning out to be the worst advice I've received yet, because so far everything I've tried to run has turned out crap.If you want to try something and don't know what just try them all!As long as you keep a backup of your current setup there's nothing to lose. Hell I've flashed roms that haven't been supported or updated in a year just to try something new. Hi my name is Dustin and I'm a flashaholic.
Also I was just thinking since I have been researching and reading and reading about AOSP, AOKP, CM11, etc and I'm wondering if some of these force closes you guys are getting could possibly be coming from the Google Apps package you're using? I saw AOKP has their own. I don't know what the difference is since I'm a noob but I thought I would throw that out there.
Doesn't matter. with every build I've used the associated gapps whatever it comes with. the problem is that it doesn't seem to fix anything, and in many cases seems to make it worse.Also I was just thinking since I have been researching and reading and reading about AOSP, AOKP, CM11, etc and I'm wondering if some of these force closes you guys are getting could possibly be coming from the Google Apps package you're using? I saw AOKP has their own. I don't know what the difference is since I'm a noob but I thought I would throw that out there.
I use a modified version of the PA 0 Day GAPPS on AOKP. I've taken out the apps of the zip that i will end up uninstalling anyways.
on L.S. I never get to the GAPPS flash before FCs start happening.
I always flash:
1. ROM
2. sit for 5 min, then setup
3. Flash GAPPS
4. set up apps and ROM
5. Flash Boost AOSP APN fix. Since i use Wifi to setup anyways.
(always clear cache and davlick when leaving recovery)
I think you're supposed to flash the gapps before you even boot the system up for the first time then you let it sit 5 minutes to do all the other stuff
Well, short of making yet another thread, I will ask again.
I can't go back to stock because it will then incessantly nag me into getting knox'd up. And I don't appreciate the idea of Samsung basically making my warranty void because I do happen to run a few apps that require root just to work at all.
I was Happy With StaticPower v2... but the incessant nagging to update to a knox'd rom is the big reason that pushed me to start looking elsewhere. But so far every single one of these AOSP ROMs has been an absolute mess.
Without fail, every time I go into settings->more (regarding mobile data)->mobile networks and even tap to view the settings below the preferred network type (such as mobile plan, etc), android.phone crashes. Intermittently while doing anything with the phone - which has mostly now been just trying to get the apps back that I want/need - I would get the android.systemui crashing and kicks me back out to the lock screen, which completely interrupts what I was doing, and that's really *expletive* annoying. And despite all the apparent included power management stuff that seems to have been added to most of these ROMs, all of them have been definitely eating more power per day than what I was running. Even on a busy day I could at least get three full days of battery with StaticPower. Every single one of these AOSP roms seem to want to drain the battery dry in 1.5 even when I'm just doing basic stuff.
So, the way I'm looking at it, I can't stay on 4.3 TouchWiz because it'll nag incessantly to update. But then there has yet to be a single 4.4 build of AOSP that actually works. So what the hell do I do now? :afraid:
- SOKP
- Would not let me update Xposed - at all. It refused to install any updates to Xposed or any other apps or updates that use it.
- What good is the GPS optimizer when it basically broke the GPS to begin with?
- Despite enabling the dolby digital driver, it certainly didn't seem to improve audio quality at all.
- Why is there no officail release of CM11 for these phones?
- AOKP
- Um, it went into a crash loop with android.keyboard, and thus I couldn't even finish the initial setup. I had to yank the battery out because the notification of it crashing wouldn't let me do anything else
- LiquidSmooth
- How about the fact that it kept nagging that it wants me to update that inspire launcher but then refuses to let me see what was updated about it.
- SlimKat
- Specifically, the fact that this one constantly made it so that no camera app could access the camera in the first place, even from a fresh boot.
- Or for that matter, the fact that i had since lost many shots that I would have wanted to keep, because SlimKat decided that it didn't need to save the pictures in the first place
AOKP? Yes, I just finished flashing that... and right out of the gate, the keyboard process stops working. So I can't even finish the initial setup.
... *expletive* seriously!? Why are there so many roms that don't *expletive* work?! Does anyone ever actually test any of these roms before shoving them on us?![]()
Yea, see, the OTA updates don't even give you the option to try and deal with it later... it's either restart and install or press the home key to get it out of the w ay. but it won't clear from the notification drawer and it puts itself right in the way to force you to accept the update.Codezero, for the Ota nag I use an app file called for fotakill.apk that you just place the app file in system/root and reboot. I've used it multiple times when I had to flash back to TW 4.3 from aokp or cyanagen roms and the nag always stayed at bay, I never got the nag after, except one time maybe, and I just clicked update later, it never did show after that though.
If you can't find the apk file let me know I'll see if I can't get it uploaded to download for ya.
If the key board fcs why didn't you just let it boot back up once you pulled the battery? May have just been a one time thingWell, short of making yet another thread, I will ask again.
- SOKP
- AOKP
- LiquidSmooth
- SlimKat
I think your right about that I use to use the full module pa gapps and every time I installed a rom I had to update the Google play services before anything Google ran so that may be a issues I use now the small gapps package with barely nothing in it and download what I need
... Could you please explain what the heck you mean by "fcs" ? I have no idea what you are talking about with that. And frankly hearing these weirdo acronyms is starting to make this situation worse and getting me stressed out.If the key board fcs why didn't you just let it boot back up once you pulled the battery? May have just been a one time thing
I think you really need to give aokp another try I recommend if you have a sdcard that you put in the back of the phone put the rom on that boot into recovery wipe data /factory reset then once that's complete if your using philz go to mounts and storage go to the option format sdcard and then install the rom
It would take me forever to address every bullet point you have but overall your having issues with everything so since you want stability run cm10.1 official release which is a 4.3 rom if you get any fcs with that it's not the rom somethings going wrong in the installation process
I use the option to clean for installing a new rom from Philz, install the rom, then install gapps, and then the boost APN fix before starting a fresh boot. Far as I understood it, that's all I had to do.
Also, why would I format the sd card now? it has the sms backup, which is the only thing I can't actually restore if I end up having to wipe the phone again. I'm not sure I understand what it is you're trying to get me to do here, other than basically delete everything I have.
