No problem. He followed the steps that always work for me and thankfully they worked for him as well. I Flash the ROM, the new PA 0-Day GAPPS Mini Modular package then the APN FIX. I've been flashing the GAPPS right after the ROM since the CM and Carbon teams started recommending it. I added the APN FIX, found that it worked and have been using that sequence ever since. That way I'm ready to go as soon as I boot out of Philz.
I've also been using the PA 0-Day GAPPS on the advice of Struckn and haven't had and issues. I do recommend staying away from the full Google package (the very 1st package) . It replaces the AOSP apps with Google Apps. That package pulls the messaging app and replaces it with Hangouts along with some other apps that AOSP ROMs need.
One thing I have noticed is that sometimes the Play update will hang. A quick reboot solves that. Since taking the Kit Kat update, that no longer happens when flashing the AOSP ROMS. Since many are not running the ND8 update, I do need to go back and add the part about the Play update getting stuck and that a reboot will fix it. I'll get that taken care of today.
As for adding new flashing steps in the AOSP section, I actually did it last night. Seems you and I were thinking the same thing lol.
The actual flashing instructions are in bold black but the header above it is in blue and red. Take a look and tell me what you think. See if you think it sticks out well enough to grab your attention. :thumbup:
