I think some of you may be very interested in these results. I am seeing significant changes in speed and radio signal.
Here's what I did to achieve the results in the screenshots below.
________________________________________
[ROM] Wicked-X with the Sprint ND8 bootloader.
I entered the hidden menu and modified the proxies and made the other changes mentioned in post #1931.
I flashed the Boost NDC modem via Philz recovery. Member, Moonknightus, states that this modem will only work on the ND8 bootloader
if you are running a custom kernel. Wicked-X has the custom 4.4.2 KT747 kernel.
I entered the hidden menu again and used the PRL Write feature to change my PRL. I switched to Sprint's PRL# 25019.
wavey
 Your MSL is usually needed to enter the hidden menu. Wicked-X did not require it. If you try this with another stock based ROM, you may need it so have your MSL handy. Also, please note that the PRL Write feature is listed under VIEW not EDIT. Yeah, I know.... that makes perfect sense.... NOT!
One more thing....... the stock 4.4.2 ROMs do not have the PRL Write feature. There is a mod that will give you access to it. Bilgerryan went ahead and added it to Wicked-X.
Check these out!!!!
