Root Boost TU Backup help?
TigerMod
i have a boost TU stock rom and kernel and have the CWR. when i try to backup i cant it says this
CWM-Based Recovery v5.0.2.7
E:Can't mount /cache/recovery/command
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
Then when i try and backup it says
Cant mount backup path
Any help?
Also the cache is mounted in the mount part of CWM
i will go in recovery. Then i will go to backup and restore. When i press backup it gives me the error message that i said in the first post.
Pull the battery out and go into recovery again. CWM is still sort of buggy; you can only do one big action per session.
If that doesn't work, format your sdcard after you save anything important on it.
The error messages about the /cache/command/log can be ignored.
i have sdcard/clockworkmod/backup and when i try to back up it cant mount it still and when i go to mount the sdcard it cant it says that it isnt found when i have the sd card in it
