If you have S-off I dont know why they wouldn't work.
I dont think the android version matters as long as you know where to put it in the ROM
Yea like rxpert said the version doesn't matter. Just look for the file *bootanimation.zip" or "htc_boot_animation.zip" and delete it and rename the new one with the same name as the old one.
Look under
system/customise/resources/
or
data/local/
yes mine is saved as spc_bootanimation.zip. I saved the new boot animation as just that and moved the original into a backups file. Im just getting a black screen. I tried a few different ones ... still a black screen.
I did ... didnt my last response just state that?
