docter4ever
Hi I have an evo 4g used revolutionary to root. Running decks ics alpha 5? maybe 6? cant remember. Anywho, The problem started with a screen lock malfunction. I would press the unlock button then slide to unlock and it would just slide but not unlock. Then would i press the lock button the screen would dim at first then go black after 5-10 seconds. I pulled the battery thinking it would restart the phone and it has been stuck in bootloop since. I can get into hboot but cant acess the phones directory when i plug it into my comp via usb. I dont have the proper sd reader on my computer. I happen to have a spare unused sd card if that means anything. Please and thank you for any help or advice.
P.s. I read the guide http://androidforums.com/evo-4g-all...g-issues-your-rooted-evo-look-here-first.html
and this was the best I found but I am running ics not cm7
If you cannot get into recovery:
Recently there have been problems with people (who happen to be running cm7) getting stuck in a bootloop without the ability of getting into recovery to get out of it. If this happens, there may still be ways of getting your phone working, but it is going to require expertise that is currently above the knowledge of the author of this guide Make a thread and someone will be happy to try and help.
http://androidforums.com/evo-4g-all-things-root/516375-stuck-h-boot-loop-recovery.html
Just read this thread, very informative and nearly spot on BUT, i cant access the phone directory.
