Root bricked phone
jdogrambo
bricked my phone working on cm7 and if i did my days on the forum are pry done ill have togo back to my incognito
Sorry to here it about the phone, hopefully we see a post from You soon saying its at Samsung getting fixed.
i forgot about download mode and then remembered so im installing drivers for odin to see if that fixes it cause download mode is the only thing i can get into
My Samsung Galaxy Prevail Just shut of when I tried to save my ROM with ROM Manager...Might have been the wrong ROM....am I Screwed...??
If you were saving a rom then you did not change your phone at all and the shutoff has nothing to do with what you did... if you were flashing a rom and flashing the wrong one then yeah... maybe...
You also gotta make sure your computer detects your phone in download mode. If it doesnt its hard brick but nothing like a trip to samsung for 2-3 weeks and it will be up and running in your hands soon.
oopsies my bad
its still wont boot past samsung logo im screwed its gunna have to goto samsung
Does it register your phone on your PC when in download mode? If it does, you are good brother. Try the whole process over again: download odin exe file, tu ops fille, and phone.tar and start odin. Get your files loaded in odinand then before plugging your phone in, boot to download mode. When your phone is ready with the yellow triangle, plug in and should change color on odin which indicates ready to flash. You could even try the odin file link from the acsyndicate site in case our link is bad here. I'm pretty sure interdepth posted one there as well. Good luck bro. We're pulling for you.
Sprint or Boost because i have a sprint tu and i couldn't boot past the Samsung logo, i needed a different .ops file and tar file for odin, once i got the right ones it booted fine.
Does your computer recognize the phone and do you have internet besides the phone and a computer connected to said internet? If so you may be able to have some teamviewer in and see if they can right the wrong.
it stoped reconizing the phone so i called samsung and im gunna send it out monday and there gunna fix it
