Is the LG Motions processor faster than our LG Connects?
the spectrum is a msm8660 tooyes it is. its the same one as the galaxy s3 if remember correctly. and pg but can it be done or do we have to w8 for the spectrum to get ics
And dunno, I dont do dirty ports.![]()
lolI'm not saying it cant be ported over, but I dont do dirty ports, so I dont know what the requirements are to be able to do or not lolwell thats a bummer, so a different cpu really makes that much of a difference I mean dont they all have to operate to the same instruction sets?
*sigh* oh well, wish the motion had a 4" screen then I would have switched over.
Dirty Port is my definition of porting a ROM built for one device to a different device. Basically swapping files out from a existing zip etc etc, aka cooked, winzipkings, etc.okay thats something I have been curious about you say dirty ports? so a dirty port is when you try to make one rom work for another phone but how does that differ from say making CM work with a different device? is it because all the files and what not is available to make a new CM rom? just curious
verses
Built/compiled, being built from source for the specific device.
yea the src is almost useless (I replied to your other post) except for the kernel src. The kernel src does include a defconfig for mpcs_us, but it wont compile as is, but then again neither will the one for the viper either. lolI mentioned this is another thread, but the LG Viper is the equivalent to the Connect and they have an ICS update on the LG Open Source site, if someone can point me in the direction of how to do a "dirty port" I'd be more than happy to try it out and test it to try and bring ICS to the Connect.
Its actually the "Viper"It appears that the LG motion is the connect but with a smaller different screen does that mean there is a chance of using its ICS rom and making some tweaks to bring it over to the connect?
Also, the motion and connect have nothing in common besides both being from LG. The Motion has msm8960/S4 chipset and the Connect has a msm8660/S3 chipset.![]()
