Alex Boullé
Could it be i need an older version of odin for an older device?
I'm not sure tbh. Maybe?Could it be i need an older version of odin for an older device?
Hmm. My phone thinks its a samsung galaxy s3, so will installing samsung galaxy y firmware (which is what my phone actually is) fail the installation? The firmware i am trying to install is correct btw.Odin usually works or it doesn't work. If a particular firmware requires a specific version of Odin, it will either let you know or fail the installation.
Considering you're bootlooping (attempting to start and rebooting in the middle) is sounds like you've downloaded firmware that was not specific to your phone model, and or country.
. Its not going well
Now when i try to install the firmware it is always unsuccessful. Its not going well
Just for argument's sake, have you tried flashing the earlier version? S5363XXLJ2
That is always unsuccessful though with a log that i mentioned up aboveThe guide from the galaxy y section says to use Odin 1.85
http://androidforums.com/threads/ho...using-odin-v1-85-also-fixes-bootloops.541141/
Can you boot into the stock recovery? Have you tried doing a factory reset from there?
Just curious now @lunatic59, as I would never have thought sim/SD would have an effect to fix the bootloop. But why does this fix? Will this cause it to boot normally with them removed but then reinserting will go back to bootloop, so this would just help in getting the phone fixed, then back to normal?
SavageRobot it does appear the case. WHen i reinsert them, it bootloops. I will find out which one causes it. Maybe i need to factory reset?
