I'm sure Verizon does not really care about this. I mean... it's so easy to set up a connection.I can't, for the life of me, get this to work. I'm using a MacBook and I can get my Droid X to pair, but it just won't connect to the network and actually work. Are there any settings I should need to change on the phone and/or computer? It pairs, supposedly connects, and then the web pages won't show up. Can anyone help me? Thanks in advance!
Edit: I got it to work...Thanks anyways!
From what I've read on some iPad forums, the only devices you can pair through bluetooth are the keyboards and earphones. I also tried pairing my X and it was recognized but wouldn't connect.
Actually this is true, Apple has really locked down there bluetooth interface, they do not have many standard bluetooth spec protocols, and severely limit developer access.
This is one large reason several long-time mac developers I know are slowly leaving iphone as a platform for contract business. Sure they still do it if someone pays, but more and more costumers are wanting to interact with embedded devices via blue tooth, and iphone OS just won't play that game. That and the $4 per that they charge if you use their frackin connector.
I have not gotten the "bluetooth peripherals" driver installed either. I want to because i want to use my HTPC audio from my phone. I am going to do a little more digging on this over the weekend, I am working nonstop till then.
I am confused how you got it to connect via access point because I can pair and connect my phone with no problem with my windows 7 netbook. However, when I try to connect using access point I get the following error:
Windows can't connect to your personal area network. Try removing your Bluetooth enabled phone from your computer, and then adding (pairing with) it again.
I've done this several times and it never connects. I've also tried right clicking on the bluetooth icon and selecting join a personal area network but that just brings up the same window as if you right clicked on the same icon and chose show bluetooth devices.
Any ideas what could be going on?
Great Thanks! This is one thing I was wondering about Froyo. Although can't you just use wifi hotspot with froyo natively?
Can you elaborate? I'm having the same issue (everything connects but web pages won't load)
Thanks
Wow, GREAT post. Thank you so much, it is truly that easy on the mac. Pair, and then click the connect to network. I had no idea it would be so easy. So we aren't going to get charged for this?
Here at work I'm getting .68 Mb/s down and .33 Mb/S up... Seems a little slow, but definitely works for news/e-mail browsing.
didn't see anyone answer you Mac... just made sure both device and computer were discoverable, paired them and just click on send file or connect to network. that simple. i found this thread because i was looking for some info on why i can't transfer a .apk file through BT. this is my first smart phone that i'm toying around with, i didn't get a chance to customize my incredible...
Uploaded with ImageShack.us
For $20 a month I would just as soon use the Verizon hotspot and not have to mess with anything knowing it works with any device I care to use.
So just to make sure, if I don't have 3G WiFi Hotspot as part of my plan, but I connect my laptop with my phone through bluetooth and use my phone as a modem for my laptop to achieve internet, I won't be billed for it? Does anyone know if that is true or not?
Ok, I figuered out how to tether with the phone. Pair the phone via Bluetooth and go to "Show Bluetooth Devices" and "connect using" and then "access point. Now you have tethered with Bluetooth
Read the thread.Your answer is everywhere.
