If I remember reading correctly they've unlocked 3G/4G, but that may just be for unlocked AT&T Notes on T-Mobile.
I have an unlocked AT&T Note on T-Mobile. How do you get 3G & 4G?
I think the current Note doesn't have the antenna in T-Mo's frequency for 3G data, and since this is a hardware issue, this will apply to any GN, rooted or not.
I did a little looking around and I.found out that a straight talk mobile simple card can be used in the n700 and in it will give you 3g. Or 3g plus on there service and it runs the same if not better than state if this is true I'm picking up this phone asap
I use my Note on Straight Talk and have really enjoyed it, you can buy a SIM here.
Welcome | Straight Talk
I heard you had to get the tmobile card? That true? Which card did you get
Sent from my Triumph using Tapatalk
You definitely don't want a T-Mobile SIM, if you buy that you'll be limited to Edge and won't get 3G. You want to buy the SIM listed as "Unlocked Phone (Phone must operate in 850 and 1900 MHz bands)."
Apparently AOL is teaming up with a company called "Cellufun" to create an ad-supported community mobile gaming channel. Sounds interesting.
Apparently, the games will be tested popular titles that have proven themselves on mobile phones already.
Take a look at http://wap.aol.com/games where you can currently play mobile games courtesy of AOL. Eh... after seeing Duke Nukem on an Android Phone I'm not sure how excited this makes me.
Well that's the thing... You can buy an unlocked phone or an att or tmobile phone... They will all work... The ONLY problem is that buying these phones out of contract is crazy expensive...
