So i was moving things around o my screen and decided I wanted the calendar on a different screen. I dragged it down and removed it from its original screen and problem is when I try to add the app to a new screen all i get is the widget (this is for the android calendar)
Any way to fix this. Should I just use the htc calendar (which loads the entire calendar not just the widget)? Are there differences between the two? Will google calendar sync to either one?
