Yes you can unroot it. Just delete the superuser app and you're good to go![]()
dont worry about unrooting it if you return/exchange it. they wont check. you cant even tell unless you really change things around.
No you cannot turn it off sadly, its like a law that all phones has to have the shutter sound on at all times to make sure the person knows that your taking a picture of them.
If you do have root access download a file explorer from the market and navigate to system media audio ui and find cameraclick.oog i believe thats the name for it there should be 2 of them delete them both to turn off the shutter sound or rename them to turn it off too![]()
