is there way make camera work even if battery is low
A adamantell Well-Known Member Jun 6, 2011 147 6 England Jul 27, 2011 #1 Jul 27, 2011 Add bookmark #1 is there way make camera work even if battery is low
Slug Check six! VIP Member Aug 1, 2009 20,518 16,993 60 Inverness, UK Jul 27, 2011 #2 Jul 27, 2011 Add bookmark #2 Yes, but only if the device is rooted. Upvote 0
N NZtechfreak Android Expert Apr 23, 2010 1,825 763 Auckland, New Zealand Jul 27, 2011 #3 Jul 27, 2011 Add bookmark #3 As per Slugs comment, only if Rooted/on custom ROM. Check XDA developers, most of the custom ROMs there have enabled camera at any battery level. Upvote 0
P planetf1 Newbie Jul 18, 2011 31 3 Jul 30, 2011 #4 Jul 30, 2011 Add bookmark #4 A bit frustrating they did this. I can kind of see the reason but they should popup a dialogue warning user and allowing them to decide... Upvote 0
steslatt Android Expert Jul 20, 2010 1,145 303 Manchester Jul 30, 2011 #5 Jul 30, 2011 Add bookmark #5 In newer firmware like kg2 and kg3 you can use the camera with low battery just not the flash. Upvote 0
tempest7 Well-Known Member Jul 23, 2010 130 16 Jul 30, 2011 #6 Jul 30, 2011 Add bookmark #6 I open up another camera app. Pudding camera, Camera 360, Magic Hour, etc and they some how take pictures regardless of your battery level. Upvote 0
M m_usman_ch Newbie Oct 29, 2011 12 1 Oct 29, 2011 #7 Oct 29, 2011 Add bookmark #7 Try LowBatteryCamera App: https://market.android.com/details?id=thepaksoft.net.lowbatterycamera Upvote 0
Sixel Well-Known Member Sep 28, 2011 138 12 Oct 29, 2011 #8 Oct 29, 2011 Add bookmark #8 I just use my camera apps, works well with low battery. Upvote 0
