csrcastro29
I have many problems with my Android phone. I hope to get help in this forums.
Metro blocks tethering so you will need a user agent spoofer to mimic eithe android or linux browser.
Firefox and chrome have addons that does this for free. Just google ua switcher for whatever browser you're using.
If you are rooted you can use wifi tether from the playstore. In settings set your profile to the lg optimus. If you're non rooted you can tether via usb with pdanet.
Are you running a custom rom?
A custom rom is like a different OS for your phone to put it simply.What is that?
The WIFI tether doesn't work
It does work, first off you have to download the latest version of the WIFI Tether, secondly under profiles you MUST set it the device profile to LG OPTIMUS S, and thirdly you MUST turn on ACCESS CONTROL, whether you use encryption or not, these are the steps you must do to get it working.
Good luck![]()
