Root can't mount internal sd card
ocnbrze
DON'T PANIC!!!!!!!!!
ok so something weird just happened. i just flashed the latest update for the pacman rom. i was going to do a titanium backup restore of my apps when it said that
the current/backup location ("/storage/sdcard0/TitaniumBackup") cannot be accessed
......weird so:
  • i checked my storage in the phone's settings and the internal storage has the "mount sd card" option. i tried to mount it and nothing happens.
  • i looked in root explorer and it said that my sdcard (not ext sd card) is not mounted.
  • i went into recovery and tried to make a nandroid backup to my internal storage and that was a no go. i could not even select it. it just keeps going back to external.
  • i tried to wipe internal storage and it said it was "unable to mount '/sdcard'
  • since i was in recovery i tried to nandroid back and see if that helped.....and it was the same thing......just can't mount the internal storage.
  • I just tried adb to see if i can get access to the sd cards and it now does not see my device.
  • right now i'm in the process of flashing a stock rom.
it seems like i corrupted the internal storage partition. since i can't wipe it, i'm not sure what to do. i'm not sure that i can format it. TB does show how much is in my internal storage. everything was fine up until i flashed the pacman rom and of course i wiped accordingly.....so i do not know what is going on.
any ideas?
ok so something weird just happened. i just flashed the latest update for the pacman rom. i was going to do a titanium backup restore of my apps when it said that ......weird so:
any ideas?
My guess would be to runn an RUU, might overwrite the partitions, clearing out the corruption.
Since you're S-off, you need to match your RUU to your radios, correct?
Don't think you want an RUU with older radios.
Very strange dood, very strange indeed. :(
hmmmmm did not think of that. thanx
i will try that after i flash the stock rom.
now the only thing that sucks is that i just updated my radios to the latest firmware. and the only ruu for the latest ota is over the free file sharing limit. i do not want to pay a monthly just to download the ruu. anybody know of another one that is free to download?
ok well looks like i will not be needing a ruu after all.
so the stock rooted 3.15 rom i just flashed seemed to do the trick. not sure what that was all about. but i was able to nandroid restore back and it seemed to give my internal storage back after the flash.
i even checked in recovery and i can make nandroid backups to the internal storage now and i'm currently doing a titanium back restore (first i had to make one from a previous nandroid backup) as we speak.
oh well crisis averted. LOL :D
go back to pac man and see if you have another issue with the internal card. I am running it now and have not had this issue. My TB restore went fine.
FYI - I do have this if you need it at some point in the future. I also have the decrypted PJ75IMG.zip (since I know you're S-OFF ;)).
Just let me know :).
yeah i made a nandroid backup of the latest pacman rom. so when the stock rom worked i just restored back to it. so far so good. everything seems to be working. just odd that it happened like that.
thanx capt. actually i would love that. i have a link to your files on the dev host site, but could not find the latest ruu there.
any ideas?
I ran into this once, going from AOKP [some beta build] to an AOSP ROM [Paranoid 2.99]. I think I neglected to wipe system, which resulted in some sort of corruption of the SD, or at least the system couldn't mount it. I ultimately reformatted the card and did a full wipe and clean install to get things working again. Needless to say this hasn't happened since.
Glad to see you're fixed up.
I'm running Jamie's PACMAN ROM now - sooo gooooood.
--Three
--Three
yeah but for me i wiped everything plus i use superwipe as well. and luckily it was not the external sd card. it was just the internal sd card.
but all seems to be fine now. rocking pacman v3 as we speak and so far so good. i was able to get my apps and data back with tb so all is good.
