Out of all jb roms, I haven't seen any with working Wimax.
If you need Wimax, it's best to stay on ics.
I believe Maui also has it working but same issue.I think he meant good and constant working 4G, many are still having issuesI believe Maui also has it working but same issue.
4G is a WIP. Turns on and searches (I don't live in a 4G area) (kushdeck/toastcfh)
Opinions on the most functional JB ROMs available for Sprint? Most seem to have a problem with Wimax.
In my biased, humble opinion, I found Panandroid 2.52 to be my favorite, even with the issues.
I did a full wipe, installed PA 2.52, gapps, rebooted, set up the phone, rebooted into recovery, installed camera fix, and that was it.
I would also say, that if you are not willing to tolerate updating roms and flashing other updates, then JB is not for you. Until they release completely stable versions of JB, you will not find a fully functional version.
I had ICS for a couple days and JB is far superior. It makes me phone seem completely new. I have an EVO 3D and I'm very happy with PA 2.52.
Looks like the new ParanoidAndroid JB got wimax working. Might wait a few days to see how things shake out with it, but seriously considering it. Very curious about JB.
I've got 2.99 on my Metro'd 3vo and it works pretty good, but I tried to get clear internet on it and it never worked, i'm not sure if that is a hardware or a software problem.
Any jb roms with (semi) working mms?
I don't know if I can find any with semi working mms, but hopefully you're okay with fully working mms
Paranoid Android
wow! This does work for vm right? (just have to ask xD) I didn't know any jb (cm10 isn't it?) roms had mms working with vm.
Paranoid android is based on cm10, so expect whatever is broken on cm10 to still be broken
Oh no! Now I feel bad![]()
I don't think it's fully working with VM. I was just assuming you were on sprint since this is in the Evo 3d thread! I haven't been following the rom thread at xda lately to see if anyone has it going fully on VM... Sorry about that!!
