oh man, time go go get s-off! lol I'm SO used to using my macbook that using my husbands Toshiba is driving me NUTS. Its SO SLOW!
I went to do the "adb reboot bootloader" and I keep getting an error saying the device isnt found. I'm really hoping I didn't totally **** my phone up or my husband is gonna kill me!
Er, as part of step 4 that is. I restarted the phone a few times into regular mode as well to see if that would get it to work but no such luck. Any ideas?!? I'm kinda freaked out right now. The last thing I want to do is prove to my husband that I shouldn't have rooted in the first place. lol
yeah, I ran the RUU. Could it be a problem with that? I figured I'll throw the zip onto my SD card and try to flash it again. Any chance that would fix it? I already checked to make sure fastboot is unchecked and USB debugging is enabled and no luck =-(
Hrm, does this mean I might be able to re-root it from here using my macbook instead of the damn Toshiba? lol
) just flash the superSU patch instead. To at least get root on your phone try this:
-Go to this post: http://forum.xda-developers.com/showthread.php?t=1538053 and download the file called UPDATE-SuperSU-v1.02.zip
- Put that file on your sd card and boot into your recovery again and choose install zip from sd card. Then select that file. Let it flash and you should be rooted.
To check, download root checker from the play store and make sure.
Flashing this super user patch on your stock rom is really the same thing as flashing a stock rom with super user. This way you are just rooting your stock rom. The other way you are flashing the rooted stock rom.
This should at least have you rooted on the stock rom, then after you have root we can figure out how to flash some other roms if you want to.
Yeah, I'm heading back to the mac since the Toshi still won't recognize the phone. Can you link me to the other post so I can see the whole thing? Thx!!
Lol, ignore me. I'm tired. Gonna go throw that zip on my phone now that I've eaten lol
That was an epic fail. I've got a picture of my phone with a red triangle and a ! on it now. I didn't brick it did I?!?
That just sounds like the stock recovery.
Just battery pull to get out of it.
DS
Yeah. took a break for a while and I'm just getting it unlocked now. I assume I can just continue as I did the first time, right? Obviously I'll be installing and running root checker as soon as it finishes up this time. I really hope there wasnt a problem again!
