dangearity
Hello All,
I recently rooted my EVO3D using the HTCDEV method because the bootloader was version 1.5.
Here are the steps I followed to root (sorry for the copy and past but I want to be as detailed as possible)
Files Used
su 2.3.6.3
TWRP Recovery
Steps Taken:
1)Take both the su.zip and recovery.img files and put them in your sdk tools folder.
2)Now do the following in ur command prompt, hitting enter after each command.
3)Code:adb push recovery.img /sdcard/And,
4)Code:adb push su-2.3.6.3.zip /sdcard/Then,
5)Code:adb reboot bootloaderUr phone will go to fastboot and should look like the after picture above. Now you can flash the twrp recovery, so do,
6)Code:fastboot flash recovery recovery.imgIt will ouput something like this,
7)Code:sending 'recovery' <5068 KB>... OKAY////writing 'recovery'... OKAY///finished. total time: 11.355sNow you have twrp recovery, so you can navigate to it. On ur phone, use the power button to pick bootloader, then scroll down to recovery and pick that. You will then be booted into recovery.
8)Here you can pick "install zip" and then pick the "su-2.3.6.3.zip"
It will flash, the you can pick "back to main menu", then "reboot system now"
9)You will boot back up and have working Superuser. I have had no trouble with Titanium Backup, Root Explorer, Quick Boot or any other app that requires root. Before you do too much, it would be good to go back to recovery and do a Nandroid backup. Always best to get one ready before you start modding anything.
All of this worked fine, and the phone was "unlocked."
Then, I flashed the most recent version of CleanRom (2.7)
Again, the phone worked fine, battery life was a little crappy.
I decided to flash Ziggy's kernel.I flashed the kernel simply by putting on the SD card, and then rebooting into recovery. This worked fine as well, but I noticed some of the buttons for example the menu popups displayed volume where it should have said more, or bluetooth options where it should have said preferences. so this is where the trouble started, I downloaded kernel manager, and flashed silverneedle through that program. Now, I am stuck at the White HTC Splash screen bootloop. The phone turns on and after 15 seconds reboots, and reboots, and reboots.
What Ive attempted:
I have done countless wipes and clears of the dalvik cache and cache
ive formatted the system and the date sections (advanced menu in twrp)
ive reflashed the rom after wiping countless times
ive tried flashing different kernels in recovery to no avail
factory reset and wipe havent helped
im not concerned losing the contents of the SD card
I need help because I already had two phone claims in the past 11 months, and if I claim another lost phone I will lose insurance for life with Asurion (sprint)
anytips or help would be greatly appreciated
i can provide any additional info
Files Used
su 2.3.6.3
TWRP Recovery
Steps Taken:
What Ive attempted:
