rom_man
Every aosp rom is missing 3d.There is no source available for that. So basically yeah, I you want jellybean you are sacrificing 3d
With 3D working that thing could be best.;
I'm not a developer, but from what I've heard, it's probably never going to happen. If there was a known way, all the developers would likely include it.
That's not to say it's impossible, it's just that no one has figured out a way yet.
Well gang. it's been long enough and I was itching for some new features and bug fixes as I bet many of you were. Here's my latest, as far as the updates:
- Updated the entire CM 10.1 source to CM 10.1-RC5
- Updated PA to 3.6
- My Linux Kernel is now at 3.0.84
- More HALO bugfixes
- Updated Audio, Display, and other Qualcomm modules
- Updated lot's of internals like my customized buildscripts, my Linaro patches, and tons more
- Fixes to ROM Control from AOKP (also updated the battery options there)
July 17th, 2013 cmbaughman
OK guys and gals, here is the first of some changes. I've updated the kernel which is going to get a ton more updates as well. There's lots of other changes most of which are in the "about" section of the Settings app. I'll publish GSM next then VM. After that I am going to update our Chaos ROM which there are a ton of updates. Thank you every one for your kind words last week. It is much appreciated. Enjoy!
Any attachments for evo V .Thanks !
Please stop asking that in this thread, when there is it will be posted in your device section. cheers
Is this still not available for HBOOT 1.58?
