So HBoot 1.57, then you are not on Sprint ??
This does make you cdma. And honestly Imo your phone should be basically the same to root as sprint. If you follow the entire newbies guide and use the superuser patch you would be stock rooted golden.
I'm already rooted, am i having issues because of a kernel version or cause my h=boot is 1.57 s-on?
I'm having this same issue. Do you mind letting me know what kernel you ended up using? Anthrax and Power Kernel both are not working for me.
