Help Chmod failed: EPERM (Operation not permitted)
P
PL13
Guest
Hi I tried to install an apk (from android-python27 project) which unzip and chmod some files in my storage, but I get the following Error (samsung s5 API 21):
Unzip extracted /storage/emulated/0/com.android.python27/extras/python/xml/etree/ElementPath.py
01-18 17:08:54.403 20996-21039/com.android.python27 W/FileUtils: Failed to chmod(/storage/emulated/0/com.android.python27/extras/python/xml/etree/ElementTree.py): android.system.ErrnoException: chmod failed: EPERM (Operation not permitted)
When I try to install the apk in my another android device (s3 mini API 16) it chmod with success. I also tried to chmod via adb but it doesnt work.
So is there a way to solve this matter? Thanks in advance...
I'm pretty sure that this is because the FUSE mounted "SD card" (your /storage/emulated area) does not support chmod:
It's not related to the change in storage permissions introduced in Kitkat (I verified that my 4.1 GNex also refuses to chmod a file on it's FUSE-mounted /sdcard).
If it worked on your S3 Mini, then it's SD card must not have been mounted with FUSE (or the target of the Python extract was not your SD card)?
