Im running Apex 1.3.1 with GBtheme and I was wondering if there is a circle battery mod for this theme. I searched around and only found that the circle battery comes with the Revolution theme. Thanks.
I also made one a while ago because Bankswood was asking for one if you want to check it out.
You can get a screenshot of it on post #4 of this thread:
http://androidforums.com/droid-x-all-things-root/242813-fission-alarm-clock.html
It's for those who are on the stock GB theme for ApeX 1.3.1:
Blue_Circle_Batt_Mod_ApeX_1.3.1.zip
Looks like this:
Would be cool if it was yellow to boot to match the default Liberty theme.![]()
Give me a few minutes. I think I can get it before I go to sleep. Are you wanting it on the stock liberty theme? or a different one.
Can you link me to one that you like? Not saying I would be able to do it fully but I could definitely work on it this weekend. That is to say if Faber doesn't see this and beat me to it. he works fast lol!
Bouchigo, you made that for me and it is awesome. My favorite battery icon. When i moved to GJ I tried to flash it but it put my phone in bootloop. I have been afraid to try and install it on Liberty. If you could mod it to work with Liberty I would reall appreciate it.
Any way to get one green to go with the Gbtheme?
If you need more help creating them lmkStock Liberty. If you can great but don't spend alot of time on it.
If I get time today (or tonight) I can use the green one I used in the revo theme on the stock apex 1.3.1 (i think thats the gb theme your refering to right? your on stock apex1.3.1 right now?)
its a "brighter" green then the one in the GB stuff though
