yeah i was getting errors too. Your best bet would be to not cook it and you remember when it showed you the preview of your battery icons? When you're looking at them right click on 0,10,...90,100 and save them as a .png. the same with the charging ones but you need only 6 images for charging. I did 1,4,8,12,16,21. Then rename the battery icons to stat_sys_battery_0.png, stat_sys_battery_10.png and so on. For the anim ones rename them stat_sys_battery_charge_anim0.png all the way through stat_sys_battery_charge_anim5.png. Then find the framework-res.apk on your computer and open it with a app called 7zip. Google it to download it. From within 7zip you'll navigate to res/drawable-hdpi this lists a lot of .pngs and other images. to make sure you're in the right place scroll down and you should see stat_sys_battery_0.png in there. Move the window to the side and then bring up the window that contains the battery icons you downloaded. Drag them all into this to replace them. Once this is done you then need to save it with 7zip or however you complete it with 7zip (i use a mac so it's all different, sorry). you will then have the edited framework-res.zip. rename it back to .apk and then you can do and adb push. Just like with adb pull but you'll put the path of where its at on your computer first then where you want it on your phone.Sorry this is hurried. I'm trying to head out for the night
