Root Clockwork Mod Recovery
Shabbypenguin
Extreme Android User
Due to the events as of late regarding Phandroid/AndroidForums i am removing all of the content i brought to the site, i still have most if not all the files, you can find me on xda or twitter if you would like a copy or to chat with me. My recent ban only further solidify my plans to leave this site. sorry for any and all inconvience.
Shabbypenguin and the Android Creative Syndicate
present to you
Clockworkmod Recovery for the LG Connect 4G​
This software is licensed under the WTFPL
/* This program is free software. It comes without any warranty, to
* the extent permitted by applicable law. You can redistribute it
* and/or modify it under the terms of the Do What The F*** You Want
* To Public License, Version 2, as published by Sam Hocevar. See
* http://sam.zoy.org/wtfpl/COPYING for more details. */
what this means is simple, you can do whatever you want with this software ;)
Download
cwm looping? download this and flash in recovery
www.shabbypenguin.com/OUDstuff/cayman/Stock_kernels_connect4g_flasher.zip this file will restore stock kernel and recovery :) for all of you testing kernels ;)
Source
Excellent, just plain excellent. Thanks to those guys that made this happen. Now, just waiting for some cool custom roms.
HI I installed CWM recovery on my phone, the i booted into recovery then i tried to make a fullbackup. then my phone froze in the middle of back up and was stuck there for about 15 min so i pulled the battery out, put in a different sd card and booted into CWM recovery using Volume - and power button and tried to do a full back up again and it froze again. then i decided to boot normaly into the phone and now its stuck in a Boot loop to where every time it only goes straight to Clockworkmod recovery. I tried to use boot loop fix from the esteem forum but it doesn't work. any help would be appreciated thanks..
Join the IRC channel for connect,markolo found a fix for that I believe.
lol i am in recovery bootloop any ideals on how to fix with out going back to stock
do a full backup while ur still in CWM. recover back to stock, root install CWM and do a restore of only data, cache and sdcard.secure and you should go back to where you where before you got stuck in cwm boot loop.
i can't get it to install..
CWM Recovery for the LG Connect 4G
One click Built by mtmichaelson
Testing and Help by markolo25 and Rlwallace
Exploit Built by djrbliss
CWM made by shabbypenguin
Press any key to continue . . .
* server not running *
* daemon not running. starting it now *
* daemon started successfully *
Device found.
Pushing CWM to Phone
1674 KB/s (5779456 bytes in 3.369s)
Rebooting device
Waiting for device to reboot
Pushing Exploit
Rebooting device again
Installing CWM Recovery
remount succeeded
rm failed for /system/etc/install-recovery.sh, No such file or directory
rm failed for /system/recovery-from-boot.p, No such file or directory
1411+0 records in
1411+0 records out
5779456 bytes transferred in 1.077 secs (5366254 bytes/sec)
Removing Trash
Finished Recovery!!!
the two rm lines/errors are fine, the fact that you got
1411+0 records in
1411+0 records out
means it worked just fine
I had it snag up on me as well, the second time around it went all the way through. However when I attempted to go into cwm manually like you suggested hold vol - and power, I held them down until after the lg logo, a screen popped up saying "to do a hard factory reset press power or to reboot press any other button", of course I hit Vol - and it just rebooted. But, can anyone shed a lil light on what happened? Did I hold down the buttons too long? And will proceeding with a hard factory reset that way wipe the phone back to stock?
Is your phone rooted?
proceeding with a hard factory reset will enter the cwm, happen to my to
i got it thank yous.. god i love this phone
hmm I am still stuck in the bootloop I tried following the steps, but now I am stuck, any ideas? need help :/ the Lg Updater cant communicate with the Phone and it only keeps coming to the CWM Recovery.
