Root ClockworkMod Recovery for Motorola Triumph
mantera
Android Expert
Just making a new thread that has download links for ClockworkMod Recovery (CWM) that are readily apparent.
First to explain to anyone who does not know what ClockworkMod Recovery is:
quoting from this post:
What Is ClockworkMod Recovery And How To Use It On Android [Complete Guide]
ClockworkMod – also known as Clockwork and CWM – is a custom recovery for Android phones and tablets that allows you to perform several advanced recovery, restoration, installation and maintenance operations on your Android device that aren’t possible with the stock recovery.
The download links are at the end of this post.
Installation Instructions:
To install CWM, do the following. If you wish to UPGRADE an existing CWM recovery that you already have installed, you still follow the following steps or alternatively, you can try the steps at the end of the post in the UPGRADE CWM USING FLASHABLE ZIP IN RECOVERY section:
1. Download the CWM Recovery file using one of the links at the end of the post. I recommend one of the latest versions--currently version 5.5.0.4. Unzip the recovery.img file from the Zip file you downloaded (using WinZip, 7-Zip, or another zip utility) onto your desktop so it is easy to find.
2. Turn OFF your Motorola Triumph (MT) phone.
3. Once the phone is off, make sure that it is not plugged into anything at this time.
4. Hold down the Power + Volume Down buttons simultaneously until the phone vibrates. (I usually hold the phone in one hand and then simultaneously press one button with my thumb and the other button with my forefinger)
5. The phone will boot into Download Mode. You will see the following types of messages on the screen:
polling, get oemsbl_mode=1
6. Now plug the phone into your computer. A drive labeled MOBILE will appear in your computer (MAC or Windows. Not sure about Linux)
7. Open the MOBILE drive and you should see a folder named image.
8. In the image folder, you will now see the recovery.img file.
9. Rename the file to recovery.img.old (or something like that) so you have a backup in case you ever want to revert back to the stock recovery.
10. Copy the recovery.img file that you unzipped in step 1 into the image folder in the MOBILE drive on the phone.
11. After the copy is complete, unplug the phone from the computer and take out the battery, wait a second, and put the battery back into the phone.
12. To boot up into CWM, hold down the Power + Volume Up and Volume Down simultaneously until the phone vibrates.
Please note: DO NOT be alarmed if you see these types of error messages. Many people (including me) get them and none have reported that the errors affect the operation of ClockworkMod Recovery:
E:Can't mount /cache/recovery/command
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
E:Can't mount /cache/recovery/last_log
E:Can't open /cache/recovery/last_log
The MT should boot up into CWM. The latest stock version 5.5.0.4 will have blue lettering.
The controls for CWM 5.5.0.4 (as well as all previous Isaacj87 versions) in the MT are:
Volume up --> up
Volume down --> down
Power --> turns screen black
Menu --> select
Home --> nothing
Back --> back
Search --> nothing
If you want to view a video of how to install CWM on the MT, Minus5252 put together this video on this post -- just don't download the version shown in the video as that version is old:
http://androidforums.com/triumph-al...-recovery-motorola-triumph-4.html#post3021427
Download links:
Current Base CWM recovery.img:
CWM 5.5.0.4 (20120527) --RECOMMENDED VERSION
MT_CWM_5504_20120527.zip
MD5: 0f847a44474b3cad5663b4409c089826
This Zip file is a flashable Zip file in clockworkmod recovery or follow the instructions above to install if you do not already have a previous version of clockworkmod recovery installed.
This version will recognize the .no_confirm or .one_confirm files in your clockworkmod folder when wiping data and cache also in addition to installing zips. See this post for instructions if you are interested in using the .no_confirm or .one_confirm:
http://androidforums.com/triumph-al...od-recovery-motorola-triumph.html#post4293429
Changelog from previous 5.5.0.4:
-Added "Power off" menu option back to main menu.
Themed CWM Versions based on sources from Tickerguy and Isaac:
b_randon14 5.0.2.7 (themed to be lime green):
recovery.img
agentc13 5.0.2.7 (Doctor Who theme using mostly blues):
http://www.mediafire.com/?p7oz58f6i9s95ro
Older versions linked here for posterity:
CWM 5.0.2.8:
MT_CWM_5028_recovery.zip
CWM 5.0.2.6 (thanks to isaacj87 and tickerguy) supports ext4
recovery-cwm-5.0.2.6-triumph.zip - reposting Isaac's link from Isaac's MIUI thread.
recovery-cwm-5.0.2.3-triumph.zip
http://tinyurl.com/7ddvpcb
CWM 4.0.1.5 (thanks to isaacj87) supports ext 4
http://tinyurl.com/82f6qup
CWM 4.0.1.4 (thanks to isaacj87)
http://tinyurl.com/7e682nk
CWM 4.0.0.9 (thanks to tjstyle)
http://tinyurl.com/7cnrjyn
UPGRADE CWM USING FLASHABLE ZIP IN RECOVERY:
If you already have a Recovery on your MT and wish to flash a newer or different recovery version, b_randon14 has provided the following flashable ClockworkMod Recovery Zip files that you can just put on your SDCard and flash as normal--I have not tested them so, as usual, do so at your own risk:
Themed CWM Versions in flashable Zip:
b_randon14_CWM_5.0.2.7.zip
Stock CWM versions:
Here is the v5.0.2.3:
Isaacj87_CWM_5.0.2.3_signed.zip
v4.0.1.5(isaacj87's):
Isaacj87_CWM_4.0.1.5_signed.zip
v4.0.1.4(isaacj87's):
Isaacj87_CWM_4.0.1.4_signed.zip
Triumph STOCK RECOVERY in flashable Zip:
MT_stock_recovery.zip
CWM Recovery - NO TOUCHSCREEN - in flashable Zip:
MT_CWM_5504_20120527_yellow.zip
MD5: a3e40a036d6123ebbb2065c8ddb6286b
Changelog:
-Changed menu and text color to YELLOW.
-Always show the "Go Back" menu options on submenus.
-The keys for this version are:
Volume up --> up
Power --> select
Menu --> nothing
Home --> nothing
Back --> back
Search --> nothing
Huge thanks to Koush on whose work all CWM is based on. If I missed anything or forgot to thank anyone, let me know and I'll update this.
What's the point of updating?
If you are using Tickerguy's CM7, you must have the new recovery, due to CM7 running of of EXT4 partitions, which the new recovery can handle. However, if you only use 2.2 ROMs you should be able to use the other builds. (There is maybe one or two ROMs that work on the old recovery and won't work on the new one.)
If you are unsure, just ask the dev of the ROM what CWM you should use to flash it. Hope that helped!
Regardless of selected option in CWM 5.0.2.3 I see the hat graphic in the center of the screen and ultimately need to press the power button to return to the menu. I had no problems with 4.x. What is going on?
** Using recovery-cwm-5.0.2.3-triumph.zip
- Tony (Motorola Triumph)
As stated in the OP:
The controls for CWM 5.0.2.3 in the MT are:
Volume up --> up
Power --> back
Menu --> select
Home --> nothing
Back --> back
Search --> nothing
Using linux I did
10. Copy the recovery.img file that you unzipped in step 1 into the MOBILE folder on the phone.
During step 12, to boot into CWM, is this suppose to vibrate non stop ?
I get error's displayed ( not sure if they are really errors) on all of my CWM install. CWM works fine and all can do nandroid backup and restore can install from zip card.
E:Can't mount/cache/recovery/log
E:Can't mount/cache/recovery/last_log
E:Can't open/cache/recovery/last_log
Any insight on what this means should i be alarmed?
Yeah mine says it everytime I boot, and trust me I can for one say I flash the crap out of my phone testing my ROM and theme, as well as doing multiple backups and restores, and everything works a-ok!
updated OP to include the latest 5.0.2.6 CWM posted by Isaac.
No need to update if you don't want to if you are already using 4.0.1.5 or 5.0.2.3 -- unless you're like me and just have to have the latest versions... :)
Has anyone ever had any issues booting into CWM holding down the power & volume keys? I’ve tried it 4 or 5 times today and my phone just boots into CM7 as if I just used the power button. I can select reboot into recovery via CM7 or Rom Manager but not by holding down both power & up/down volume keys. I can’t imagine it’s just me being stupid which is always a possibility but I have had this phone since the week it came out and have booted into CWM this way more times than I can imagine. Have also verified that both my volume keys are working as that was my first guess at the problem. Otherwise I haven’t made any changes other than flash manteras OC Kernel and I can’t see how it could affect anything when the phone is turned off.
Awesome thread! I just did this and it's working like a charm. Backing up my current ROM. Thinking of flashing ROMS onto my Triumph later on.
mantera, what files need to be edited to change the color of the recovery (in the repo). I'd like to build my own themed version. I already changed the background pics, but where is the file(s) that determine the color of the text. I currently have my own built from Issac's repo.
